Re: serial numbers on a M
Posted by John (SC) on October 27, 2002 at 15:36:20 from (206.74.216.103):
In Reply to: serial numbers on a M posted by Dan on October 27, 2002 at 15:16:04:
On the clutch housing just below the air filter.Held on by four rivets,rectangular in shape.If no tag is there look for four holes and that will tell you if you have one or not.Also look on the engine,just below number 1 plug on a flat surface will be FBKM follwed by some numbers,that will get it pretty close.
Post A Followup
: Re: Re: serial numbers on a M
