Re: Re: Re: D301 turbo ?
Posted by Harold H on October 28, 2002 at 05:30:23 from (207.244.60.143):
In Reply to: Re: Re: D301 turbo ? posted by Morgan on October 27, 2002 at 13:05:12:
Morgan,
Look behind the glove box, or on top of the glove box, or possably under the seat and there may accidentally still be a line sheet glued somewhere in your truck. This sheet showed everything that was on the truck when it was built. Slight chance it's still there but if it is it would answer all of your questions about original equipment. A special order may have been possable but I know the D-301 was a 1600, 1700 option because at the time I thought IH should have made it an option on the light duty trucks. Another possability is that it may have been an option on export trucks.
Harold H
Post A Followup
: Re: Re: Re: Re: D301 turbo ?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
