Re: timing a mag
Posted by F14 on October 28, 2002 at 13:20:22 from (216.204.137.117):
In Reply to: timing a mag posted by carl on October 28, 2002 at 10:05:33:
Sounds like you need to pull the mag off the mount and move it one tooth on the drive gear. After you do that, you'll have to reset your adjustment slots, which should give you the extra advance you need and put your adjustment closer to the center of the range.
Post A Followup
: Re: Re: timing a mag
