Re: Industrial Farmall Super A
Posted by Farmer Bob on October 28, 2002 at 17:45:24 from (66.152.73.250):
In Reply to: Industrial Farmall Super A posted by Tom Zenk on October 28, 2002 at 13:46:53:
Just a thought, I've done this couple of times and used some grade 8 bolt to fit the threads in the end of the crank. Washer it up under the head of the bolt to catch BOTH hand crank bosses in the new pulley and, combined with the heating up of the pulley ahead of time, draw the pulley carefully onto the end of the crankshaft after lining up the key and keyway. You will have to chock the wheels and put tractor in gear before doing this. I just wrap a cold towel over the inward end of the pulley to precool it before it gets near the new seal. If you marked the crank where the old pulley was you should be able to tell how far to pull the new pulley onto the crankshaft. This procedure eliminates the risk of damage to the bearings and or crank.//FB
Post A Followup
: Re: Re: Industrial Farmall Super A
