Re: 1947 Farmall A cold start
Posted by Pete on October 29, 2002 at 15:55:05 from (64.12.97.13):
In Reply to: 1947 Farmall A cold start posted by Mark on October 29, 2002 at 09:45:04:
Mark...others already gave you good advice, but another thing you might want to check is the spark plugs.
I have a Super A (same engine as the A)and I had the same problem as you in the winter. I did all the usual tune-up things and still it was hard to start. I then changed from a D-15 spark plug to a D-21 plug and now it starts much much better in the cold wheather.
Pete
Post A Followup
: Re: Re: 1947 Farmall A cold start
