Farmall Tractors Discussion Board
Re: Super A Alternator Conversion!
Posted by Bob M on August 25, 1999 at 04:38:10 from (192.232.120.194):
In Reply to: Super A Alternator Conversion! posted by Bill {Antique Acres} on August 24, 1999 at 17:15:17:
Bill -
Looked at a BN fitted with an alternator at a show last weekend . Appeared they used the old generator bracket and fitted the alternator onto it using a piece of threaded rod and some properly spaced nuts for the pivot. Didn't look close enough to see how they tensioned the belt - believe however they cobbed slotted tension arm from a junkyard part.
Bob
Post a Followup
: Re: Re: Super A Alternator Conversion!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
