Farmall Tractors Discussion Board
Re: Super A Alternator Conversion!
Posted by Greg on August 25, 1999 at 04:56:44 from (216.128.143.174):
In Reply to: Super A Alternator Conversion! posted by Bill {Antique Acres} on August 24, 1999 at 17:15:17:
Bill, I used the factory gen mount, with a delco internal reg off 78 chev pu. Take a stick of 3/8 allthread 3inches longer than the gen mount, line the pulleys up and measure the distance left, make a spacer to take up the space in the gen mount. Take off the adjusting bracket and turn it over mounting it back in the same hole, that will align the adjuster with the alt. The adj will be short, I made an extension out of 1/4 x 1 flat bar about 3 in long to make up the difference. Take an old fanbelt , cut it to fit around the pulleys to measure for the lenght of the new blt, get this close cause there is not much clearence for the hood. Hope this helps
Post a Followup
: Re: Re: Super A Alternator Conversion!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
