Re: Re: Farmall-M Tricycle Stability ...revisited
Posted by dick on October 30, 2002 at 08:54:38 from (209.245.15.65):
In Reply to: Re: Farmall-M Tricycle Stability ...revisited posted by Gary on October 29, 2002 at 21:40:07:
Maybe this will make George's point more easy to understand:
Take a baseball bat, point it up into the air, and balance it on your hand from underneath. That's somewhat like a narrow-front tractor with the pivot point where the tires meet the ground.
Then take the bat, point it downward, and hold it from the top. That's somewhat like a wide-front tractor with the front pivot point elevated.
This overstates things a bit, but hopefully should make George's point more clear.
Post A Followup
: Re: Re: Re: Farmall-M Tricycle Stability ...revisited
