Re: Darn Alt. on M!
Posted by Terrance on October 30, 2002 at 11:57:00 from (66.231.200.76):
In Reply to: Darn Alt. on M! posted by Ty on October 30, 2002 at 05:21:31:
Most likely culprit is your regulator and not the altenator.If your regulator is bad it will cause the electricity to flow through the altemator to ground.An altenator will charge just fine with the stock size pulley no need to go to a smaller pulley,they are usually turning at about 2-3 times the crankshaft speed so even on a slow turning tractor its turning fast enough to charge the battery.I would look in an auto repair manual for the proper method of testing your regulator and altenator and save your self money and aggrevation.There is no reason to change your system over to another set up unless it is totally shot could amount to a fair amount of work.It is always easier to repair what you have than to change it.
Just my two cents
Terrance
Post A Followup
: Re: Re: Darn Alt. on M!
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
