Re: Farmall 400 PTO
Posted by Hugh MacKay on October 30, 2002 at 18:11:40 from (64.228.11.44):
In Reply to: Farmall 400 PTO posted by matt on October 29, 2002 at 12:39:39:
Matt: Sven may well be right, however if you want to check to see what you need, here is how. Park tractor so front wheels are 2.5 feet below the rear wheels. Remove the plate (4 bolts) at rear of tractor where PTO normally goes. With tractor at that angle you will not loose any rear end oil. If tractor has internal parts for PTO you should see a shaft in about 15" to 18" same spline as PTO. At this point and if shaft is there, you naturally want to know if it is live PTO or not. Get a friend to start the tractor and push in clutch. If that shaft stops, tractor is equiped for standard transmission PTO. If the shaft continues running with clutch in, you know tractor is equiped for Independant Power Take Off.
Post A Followup
: Re: Re: Farmall 400 PTO
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
