Re: capacities for Super A
Posted by Hugh MacKay on November 01, 2002 at 03:02:45 from (216.208.58.144):
In Reply to: capacities for Super A posted by The Old Crow on October 31, 2002 at 22:44:30:
I don't have exact figures on capacities, however this is what I have been using for 15 years, some longer than that. Motor oil about 5 qts with filter change 15W - 40; Hydraulic oil about 4 quarts Hy-tran only for 35 years; Steering box about 1 quart gear oil 90W; Transmission volume 4quarts, 5 quarts with belt pully and pto. gear oil 90W; Radiator, complete cooling system 15 quarts, antifreeze mixed for your climate; Final drives 3 pints each gear oil 90W. These figures on volume are from Farmall 130 manual, radiator and crank case may be a bit smaller on SA. I have both tractors. Steering box on my SA seemed to be an habitual leaker, even after several rebuilds. I drained it completely, put a grease fitting in drain and pumped grease in until it came out the fill hole. The entire caviety is filled with grease. My thinking is worm and cog will plow their trail through grease. With caviety full add a few pumps every time you grease tractor. No more mess and has been working for 8 years.
Post A Followup
: Re: Re: capacities for Super A
