Re: hydraulic fluid type and wieght
Posted by Steven@nd on November 01, 2002 at 18:27:47 from (12.23.184.242):
In Reply to: hydraulic fluid type and wieght posted by Mark Kinman on November 01, 2002 at 18:12:15:
You should use CaseIH Hy-Tran or equivalent hydraulic oil. The problem you are having with your regular 10 weight oil is that it foams, Hy-Tran will not.
Post A Followup
: Re: Re: hydraulic fluid type and wieght
