Re: Should fire go to starter with ignition switch off
Posted by Glenn(WV) on November 01, 2002 at 18:46:04 from (65.134.243.182):
In Reply to: Should fire go to starter with ignition switch off posted by abane on November 01, 2002 at 16:45:55:
Same for my Farmall 100; I can crank the starter over regardless of how the ignition switch is set.
Post A Followup
: Re: Re: Should fire go to starter with ignition switch off
