Re: Re: 300 utility coolant plumbing
Posted by John on November 01, 2002 at 20:01:22 from (12.84.14.87):
In Reply to: Re: 300 utility coolant plumbing posted by Charlie on November 01, 2002 at 15:19:44:
Thanx for the quick responses. Sounds like I can simply remove the 'T' fitting at the coolant temperature sensor and mount the sensor directly into the head, as well as removing the hose and other fittings. What goes in the block on the left side? Is there a theaded plug, or maybe a drain cock that screws into this (left) side of the block.
Post A Followup
: Re: Re: Re: 300 utility coolant plumbing
