IH 300 problem
Posted by dumas on November 03, 2002 at 08:43:16 from (66.153.10.28):
A friend has a IH 300 he got from his grandfather. It starts and runs fine in neutral but will suddenly stop and act like it is in gear. He has to pull it with his truck to get it unstuck. Then it starts and runs fine again until it again stops with the same problem. Any thoughts? Thanks.
Post A Followup
: Re: IH 300 problem
