Re: Hard Starting Farmall H !!
Posted by The Red on November 03, 2002 at 10:47:06 from (12.84.240.65):
In Reply to: Hard Starting Farmall H !! posted by Bob on November 03, 2002 at 10:43:59:
Choke wise, I crank 2 or 3 cranks on full choke, then crank with no choke. How fresh is your various ignition components? Might check the points to see if they are clean and set correctly. Your timing might also be off.
Post A Followup
: Re: Re: Hard Starting Farmall H !!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
