Re: Good Super C Rebuild Day
Posted by Farmer Bob on November 03, 2002 at 21:53:23 from (66.152.73.55):
In Reply to: Good Super C Rebuild Day posted by Peabody on November 03, 2002 at 19:51:35:
All's good that ends well! Hope you had the same luck with your new clutch as I had last spring. Once installed, there was no adjusting necessary with the linkage. Even the pedal freeplay was correct. Good luck with the remainder of the restore.//FB
Post A Followup
: Re: Re: Good Super C Rebuild Day
