Re: Re: Re: Re: Re: Re: Re: FARMALL H WITH HEAVY METALIC NOCK
Posted by Harry on November 04, 2002 at 15:19:39 from (4.63.64.91):
In Reply to: Re: Re: Re: Re: Re: Re: FARMALL H WITH HEAVY METALIC NOCK posted by STEVEN H on November 04, 2002 at 14:55:35:
Steven, It sounds like you found your problem!
A bolt stuck in the top of a piston is definetly a problem. When you remove that piston and rod, check them against one of the other ones to make sure that it is not bent in any way. Also check the wrist pin for trueness. Lay it on a piece of flat glass and roll it along it's lenght and check for any warpage.
Is the piston in question still in one piece?? If it has any pieces missing, you need to take the timming cover off, and take the oil pump screen off and check for pieces of the piston that may be wedged somewhere in the engine.
I hope everything else is still intact, and you will have her up and running.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: FARMALL H WITH HEAVY METALIC NOCK
