Re: Re: PISTON REPLACEMENT
Posted by Jonathan Mirgon on November 04, 2002 at 18:13:10 from (205.208.128.53):
In Reply to: Re: PISTON REPLACEMENT posted by Al on November 04, 2002 at 17:24:26:
you should use the same piston as the other three in the engine, changing it will result in imbalance which will cause engine vibration. you will also be making the compression ratio different on one cylinder which will foul things up to. Your tractor would run, but very poorly, go ahead and do the old girl a favor and replace them all and rering them too.
good luck
J Mirgon
Post A Followup
: Re: Re: Re: PISTON REPLACEMENT
