Re: 460U Wheel Weights
Posted by dick on November 05, 2002 at 09:27:35 from (64.156.38.239):
In Reply to: 460U Wheel Weights posted by Chuck Yearous on November 05, 2002 at 06:25:12:
Assuming you have the standard 28-inch wheels, the most common IH wheel weights (used on Hs and Ms and the like with the 38-inch wheels) are likely a problem; their inner bolt circle is 17 inches, and you've probably got 16 inches, plus the hub to worry about.
IH did make a smaller wheel weight for the 300U, #365321R2, which has the smaller bolt circle and is tapered to avoid the hub, but they're pretty rare. This is probably what IH had in mind for your tractor, also, but finding enough of these for your purposes is probably unlikely.
Fortunately, wheel weights for the Ford, Massey, and other tractors with 28-inch wheels seem to work OK (I've seen them on a number of IH utility tractors), but you'll want to get out your tape measure. LOL.
Be careful - these things are heavy and awkward, especially if you're trying to put them on by yourself.
Post A Followup
: Re: Re: 460U Wheel Weights
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
