Re: Re: Re: H gas tank, how tightly mounted should it be?
Posted by John on November 05, 2002 at 15:30:20 from (192.233.162.102):
In Reply to: Re: Re: H gas tank, how tightly mounted should it be? posted by Ted on November 05, 2002 at 14:05:27:
I tightened the nut that far so I can still get the cotter pin through the hole and still get it to touch some of the slot in the nut. My tank isn't sliding back and forth but I can shake it because of the springs/ rubber pads. Should it be tighter? It was hard to tell with before with the origional pads because they sort of glued everything together . Thanks.
Post A Followup
: Re: Re: Re: Re: H gas tank, how tightly mounted should it be?
