Re: Best IH or Farmall for pulling
Posted by redhead on November 05, 2002 at 17:19:09 from (65.234.210.174):
In Reply to: Best IH or Farmall for pulling posted by Josh on November 04, 2002 at 20:36:59:
If your pulling 7500 or less the M is the ticket, 100 hp with the right parts and very dependable. If your sights are set higher on weight/class/speed, better go to the 1066, it's been down the track more than all the other put together. Good Luck.
Post A Followup
: Re: Re: Best IH or Farmall for pulling
