Re: Battery and Hand Crank
Posted by Red Dave on November 06, 2002 at 10:08:48 from (24.104.94.34):
In Reply to: Battery and Hand Crank posted by Randy Gann on November 06, 2002 at 10:02:23:
Assuming it's out of gear and all the other obvious thing shave been checked, take a look at the starter. If you tried to crank it with the starter, the starter gear may have engaged the flywheel and stuck there. Loosen the bolts that hold on the starter and rattle it around some. Then see if it'll crank by hand.
Post A Followup
: Re: Re: Battery and Hand Crank
