Re: Governor on '51 Super C
Posted by gene b on November 07, 2002 at 05:02:22 from (63.25.167.171):
In Reply to: Governor on '51 Super C posted by Brian Ordway on November 06, 2002 at 20:08:06:
There is a spring in the gov housing and that mite be broken if you dont get any response at all just fast idle. Do be careful taking apart as the geat that runs it must not be removed or you will get engine out of time. SO be careful just take gov housing off and let the rest in place.
Post A Followup
: Re: Re: Governor on '51 Super C
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
