Farmall Tractors Discussion Board
Re: FARMALL SUPER MTA MISSING CYLINDER 3
Posted by Village Blacksmith on August 25, 1999 at 20:28:13 from (205.188.192.37):
In Reply to: FARMALL SUPER MTA MISSING CYLINDER 3 posted by MIKE on August 25, 1999 at 19:05:19:
If you have spark to the plug, is the spark getting through the plug. Try a substitute plug. If that doesn't work, pull the valve cover off and inspect the valve movement and clearance in the tappets. Did this start suddenly? Also, a compression check will tell you a lot about the valve operation, if you have a tester handy.
Post a Followup
: Re: Re: FARMALL SUPER MTA MISSING CYLINDER 3
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
