Re: Questions on my H
Posted by Bob M on November 07, 2002 at 18:42:39 from (24.169.120.138):
In Reply to: Questions on my H posted by John on November 07, 2002 at 18:32:23:
You got the stop bolt in the correct location! (right side of the tractor, front hole). If you peek up under the front end casting, you'll see a crescent-shaped slot the stop bolt is supposed to move inside.
For the shock absorber, tighten the nut until the rubber bushings are squeezed so their outside diameter matches the diameter backing washers, or a bit more.
Post A Followup
: Re: Re: Questions on my H
