Re: Water pump belt tension
Posted by Farmer Bob on November 07, 2002 at 23:10:43 from (66.152.73.8):
In Reply to: Water pump belt tension posted by Roger seargent on November 07, 2002 at 20:15:18:
The manual says you should adjust the fan belt so you have 1" of flex in the middle of the run between the two pulleys. I've always taken that to mean 1/2" each way of where it sits when tractor is shut off.
Post A Followup
: Re: Re: Water pump belt tension
