Re: Farmall M Diesel
Posted by Sven on November 08, 2002 at 07:05:54 from (207.230.238.66):
In Reply to: Farmall M Diesel posted by Richard Fazio on November 08, 2002 at 06:28:48:
These are true compression ignition (diesel) engines. They use injectors while running on diesel. The gas side is only used for starting. Gas side is spark ignition with either distributor or magnito, spark plugs, carburettor. The head has a set of valves that open an ignition chamber when running on gas, provides lower compression for gas running. No they are not converted gas engines. IH made the MD, SMD, WD6, SWD6, 400D, and 450D engines gas start diesels. I have 2 400D's with about 8000hrs on each which I use regularly. They seem fairly fuel efficient, no turbo or glow plugs, on these models. I like them and consider them very unique and powerful tractors.
Post A Followup
: Re: Re: Farmall M Diesel
