Re: Float Sticking
Posted by old on March 28, 2009 at 11:47:53 from (4.245.7.162):
In Reply to: Float Sticking posted by Bud W on March 28, 2009 at 11:32:15:
Some times you can hit the side of the carb with the handle of a screw driver etc. to get it un stuck. You can also try this and it works some times. Drain the carb by way of the drain plug. Turn it on and try to start it, that clears any gas that was causing it to flood. Then turn it off, turn on the gas valve and count to say 50, turn the gas back off, then try to start it. Most of the time they will start. Then turn the gas back on and you may luck out and it will run fine till you turn it off
