Re: starting a MD
Posted by Haas on November 08, 2002 at 18:39:53 from (166.72.245.6):
In Reply to: starting a MD posted by GEA on November 08, 2002 at 11:32:08:
All the MDs I have seen you push the starting switch over lever forward to get the engine in the gasoline starting mode. It should latch in the forward position. Four things happen when you change to gas position. 1. the decompression valves in the head are opened. 2. the ignition is switched on so the plugs will get a spark (the switch for this is in a chamber in the front end of the intake manifold. 3. butterflys in the manifold are positioned so that air can flow though the carburetor. and 4. The carburetor float is released so gas can flow. In diesel position, the float is locked up to stop gas from flowing. The diesel speed control lever should be in the shut off position (down) for starting in gas mode. Once you are running on gas and the engine has had a few minutes to warm, pull back the switch over lever and at the same time advance the diesel speed control to around mid range. Puff of smoke and a roar and you are running on diesel. To shut down, reverse the procedure to get back running on gas, turn off the gas to the carb and let the gas run out until it dies. Then put the change over lever back to diesel so the decompression valves and cool while seated. If not seated, they can warp. I should also note that in gas mode, the only engine control is the choke. You may have to fiddle with the choke as the engine warms. If you need to change the throttle setting for gasoline, you have to remove and take apart the carburetor.
Post A Followup
: Re: Re: starting a MD
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
