Re: Starting Super C with a hand crank
Posted by Phlogiston on November 08, 2002 at 20:39:57 from (65.129.80.51):
In Reply to: Starting Super C with a hand crank posted by One Row on November 08, 2002 at 20:01:49:
All the pointers he gave you are right on the mark. Especially the one about proper thumb placement. But before you try to hand start your tractor, make sure the timing is right on the money. Mis-timed tractors are the reason they will try to bite you. If your timing is good, you will not have a problem.
Phlogiston
Post A Followup
: Re: Re: Starting Super C with a hand crank
