Farmall Tractors Discussion Board
Re: Replacing Farmall B front end
Posted by Stan(VA). on August 26, 1999 at 05:59:08 from (207.172.109.177):
In Reply to: Replacing Farmall B front end posted by Scott on August 25, 1999 at 21:58:28:
Yes, but the front will be offset to the right with pivot point under the gear box instead of under the motor. So not sure if you would gain or hurt stability.
Stan(VA).
Post a Followup
: Re: Re: Replacing Farmall B front end
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
