Re: Help!! New O-rings leak!!!
Posted by Jim on November 10, 2002 at 17:20:27 from (205.188.209.78):
In Reply to: Help!! New O-rings leak!!! posted by Jason on November 09, 2002 at 17:19:00:
Before you tear the engine down, drop the oil pan and use a radiator pressure tester to pressurize the cooling system - if the oring is bad or leaking you will see antifreeze coming from around the bad one. have done this before and left set overnight and checked to see where leak is at.
Post A Followup
: Re: Re: Help!! New O-rings leak!!!
