Re: 6 volt to 12 volt wiring on cub
Posted by Bob M on November 10, 2002 at 17:45:36 from (24.169.120.138):
In Reply to: 6 volt to 12 volt wiring on cub posted by Kevin Dunbar on November 10, 2002 at 11:03:58:
Kevin - you need some resistance in the line between the ign switch and the #1 alternator terminal. Can be a small light bulb (a #168 side marker/instrument panel lamp is good) or a 10 to 40 ohm resister.
You can also use a diode in place of a lamp/resistor. I forget which way the cathode should face - however trial and error will quickly tell you which way is correct. Note: Use a diode rated at 1 amp and 50 PIV or higher.
Post A Followup
: Re: Re: 6 volt to 12 volt wiring on cub
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
