Re: Re: Re: Super A Farmall update
Posted by Phil Auten (Tx) on November 11, 2002 at 04:03:39 from (208.189.120.213):
In Reply to: Re: Re: Super A Farmall update posted by kevin on November 10, 2002 at 20:02:27:
Kevin,
If the crack is external it can be fixed with JB Weld. I've seen it done that way on some cracks you wouldn't believe and it works!
Good luck,
Phil
Post A Followup
: Re: Re: Re: Re: Super A Farmall update
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
