Re: Farmall M wiring
Posted by Don LC on November 11, 2002 at 05:30:08 from (24.166.248.35):
In Reply to: Farmall M wiring posted by David on November 10, 2002 at 15:48:56:
The switch is to keep the battery from running down when the tractor is not running.....There is a better way....Go over on the left side of this page to "RESEARCH & INFO " click on ARTICLES, follow down to " A Step by Step 12v. Conversion" by Bob Melville....that tells you every thing you need to know, to do it right.....good luck.......
Post A Followup
: Re: Re: Farmall M wiring
