Re: slow turn over
Posted by Ben C. on November 11, 2002 at 12:02:18 from (192.76.82.90):
In Reply to: slow turn over posted by mwkellner on November 11, 2002 at 11:22:28:
Does your battery voltage come back up to 6 volts after you release the starter ? If not it is not fully charged or has a bad cell. To check your generator output read the voltage accross the batttery with the engine not running, then start the engine and read the battery voltage again. If the the voltage is higher with the engine running then the generator is charging.
Not real sure what the running voltage should be but I think it would run between 6.6 and 7.6 volts.
Ben C.
Post A Followup
: Re: Re: slow turn over
