Re: SM cam gear again
Posted by Bob M on November 11, 2002 at 18:07:00 from (24.169.120.138):
In Reply to: SM cam gear again posted by Bart on November 11, 2002 at 15:13:15:
Bart - I wouldn't trust just Loctite to hold that nut! There should be a stamped steel "keeper" washer under the cam nut with a tab that sticks into the keyway on the cam gear. After you get the cam gear nut torqued down you bend a corner of the washer up against one of the nut flats to keep it from loosening.
HOWEVER it's been my experience (once a couple years ago with my SM, and twice recently with a buddy's 400) that the nut can work loose even with the keeper in place. My friend with the 400 has gone so far as to put tack weld between the nut and exposed camshaft threads to be certain it won't come loose again. (The most recent failure destroyed both the cam gear and the shaft - lotsa $$$ to replace!!)
Post A Followup
: Re: Re: SM cam gear again
