Re: Re: Re: M jumping time
Posted by Dan on November 11, 2002 at 18:43:01 from (12.104.68.200):
In Reply to: Re: Re: M jumping time posted by k.wade on November 11, 2002 at 16:40:09:
Do you always turn the distributor the same way to get it to start? Unless the outside is moving by itself you would keep working it around. It is possible that the distributor advances when you are running it fast, then doesn't return. Before replacing the distributor I would take it apart and clean and oil it. There are 2 points ahead of the distributor to grease, most times they have plugs in the holes as they don't take much but perhaps no one has ever greased yours.
Post A Followup
: Re: Re: Re: Re: M jumping time
