Re: Farmall H a wiring diagram of an H
Posted by Don LC on November 12, 2002 at 12:30:27 from (24.166.248.35):
In Reply to: Farmall H a wiring diagram of an H posted by John In Iowa on November 11, 2002 at 17:04:27:
Does the tractor start ,charges and run OK? Does the Alt. only have one wire comming off of it? If so there will be a couple of wires that the new system doesen't need....Just tape them off you dont need them.......Bob sent you the 3 wire set up,that works also....But I think you have the one wire set up,witch doesn't use the two smaller wires on th alt.
Post A Followup
: Re: Re: Farmall H a wiring diagram of an H
