Re: Re: Farmall-M Single Front Change
Posted by Bob M on November 13, 2002 at 05:28:29 from (165.170.128.66):
In Reply to: Re: Farmall-M Single Front Change posted by Dan on November 12, 2002 at 20:20:18:
Good point! The cap screw that goes in the right front flange hole has a special extended (higher) head. The extended bolt head sticks up into a crescent-shaped slot cast in the underside of the fixed bolster. It then limits how far you can turn the front wheels left and right.
Punch below for a photo showing the stop bolt as the pivot shaft is being installed...
Post A Followup
: Re: Re: Re: Farmall-M Single Front Change
