Re: Permatex Qick Solder Radiator Repair
Posted by Chris Brown on November 13, 2002 at 14:22:13 from (65.69.164.225):
In Reply to: Permatex Qick Solder Radiator Repair posted by PatM on November 13, 2002 at 11:07:08:
I dont know aything about quick solder.But I have used JB weld in a pinch,It lasted for at least two years and I sold the truck with it still holding.Quick solder sounds like an epoxy type stuff to me,I am sure it will work for a while.Get it real clean,I used carb cleaner to degrease and then a little muriatic acid(swimming pool acid) make sure to clean it up good after.
Post A Followup
: Re: Re: Permatex Qick Solder Radiator Repair
