Re: Re: Re: MW Carb??
Posted by randy hall on November 14, 2002 at 09:27:15 from (208.231.151.41):
In Reply to: Re: Re: MW Carb?? posted by Doug on November 14, 2002 at 08:01:10:
when i started farming in '73 i got a kit for an h. it consisted of a new venturi and a drill bit to make the hole bigger in the load jet. later i got a kit for an m and when i went to drill the jet bigger the bit fell right in, the last owner had beat me to the draw.
Post A Followup
: Re: Re: Re: Re: MW Carb??
