Re: Wide front on SM cotton picker tractor?
Posted by Old Hand on November 14, 2002 at 15:12:24 from (64.12.97.13):
In Reply to: Wide front on SM cotton picker tractor? posted by Hayne D. Matthews on November 13, 2002 at 17:10:53:
Since yout tractor has the flanged axle housing it would have been a high drum picker. There is no way you could run standard wide front on high drum the picker had dropped drive axles similar to MV the standard wide front would have tractor about 16 inches off level causing picker snouts to stick up above cotton.
Post A Followup
: Re: Re: Wide front on SM cotton picker tractor?
