Farmall Tractors Discussion Board
Re: SA has slack in rear wheel
Posted by p on August 26, 1999 at 15:05:50 from (209.186.155.116):
In Reply to: SA has slack in rear wheel posted by Hugh on August 26, 1999 at 15:02:03:
Someone correct me if I am wrong but aren't the rear bearings adjustable? (like the Cub) Sounds like the bearings are loose and then the seals blew.....
Post a Followup
: Re: Re: SA has slack in rear wheel
