Farmall H carb.
Posted by Eddy on November 15, 2002 at 11:25:24 from (209.223.254.9):
Thanks to you guy's for the help, it didn't do the trick however. The new engine still runs rough (pops ect.). Should I go next to the timing, points, ect.. What's any "easy" way to reset the timing? One other thing, on the overhaul-when I pulled the heads the pistons were not flat, but ported, I assume not orginal due to The original rings and inserts would not fit and required a re-order. I've owned this H for 20 years, someone B4 me apparently went for a higher performance engine.
Thanks
Post A Followup
: Re: Farmall H carb.
