Re: bushing for temp gage twisted off, HELP!!
Posted by Bus Driver on November 15, 2002 at 16:35:26 from (65.165.152.215):
In Reply to: bushing for temp gage twisted off, HELP!! posted by Terry on November 15, 2002 at 15:57:51:
If you have a good selection of drill bits, the bushing can be drilled out by using bits that are slightly larger than the hole and stepping up to the next size bit for the next operation. Increase the hole size the least amount possible with each step. When the threads in the head show as the bit starts, stop drilling and gently use a small chisel or punch to remove the remaining metal slivers from the threads. Use a tap to clean the threads.
Post A Followup
: Re: Re: bushing for temp gage twisted off, HELP!!
