Re: Farmall H Timing
Posted by Andy Martin on November 18, 2002 at 15:02:49 from (12.74.161.243):
In Reply to: Farmall H Timing posted by Eddy (Tx.) on November 18, 2002 at 13:23:27:
Set the no. 1 cylinder to TDC. Use the timing mark.
Loosen the distributor drive and rotate the housing until the points just open. Gently hold the rotor bug in the retarded direction to make sure you get accurate timing.
For a mag, it should just trip as the crank passes TDC.
For either, they are timed at TDC and mechanical advance makes the engine run right. If the springs and weights are not free the advance will not work and the tractor will experience reduced power and run hot.
Post A Followup
: Re: Re: Farmall H Timing
