Re: Farmall M Replacement of Fan Belt
Posted by Bob in SE Nebraska on November 19, 2002 at 05:28:07 from (162.40.71.172):
In Reply to: Farmall M Replacement of Fan Belt posted by Nick Williams on November 19, 2002 at 05:02:34:
The front half of the pulley of the water pump unscrews to allow for the removal and replacement of the fan belt. There is a set screw and locking nut that will release the front half of the pulley. Lube up the threads in front of the pully which helps. The fan belt will pass over the fan blades kind of from the bottom and over one blade at a time.
Bob
Post A Followup
: Re: Re: Farmall M Replacement of Fan Belt
