140 and Hay
Posted by Avery on November 20, 2002 at 04:58:24 from (206.107.117.6):
Question, Can someone explain type hay equipment which can be used with a International 140. I am familiar with that type tractor. Am not familair However with type equipment which can be used in conjunction with the 140 for hay. Specifically, are there some sickle bar mowers which International made to go with the 140 which can be used to mow hay, And are there some type rake which was made that can be used with 140. Basically am asking what type equipment do I need to cut and rake hay using a 140. Land needs something to be done with it hay would be good option. And don't want to invest in bunch of expensive equipment. Like to use what already have. I'll custom out the baling. Thanks
Post A Followup
: Re: 140 and Hay
